Home Forums Products Stompboxes Possibility to morph between presets on Blackhole pedal? Reply To: Possibility to morph between presets on Blackhole pedal?
#155843
bohan
    fabeck01 wrote:
    I'm wondering whether it is possible to morph between presets on the Blackhole pedal using an expression pedal connected to the rear jack?
    The description says: "Map any combination of parameters to an Expression Pedal". The manual says: "An Expression Pedal can be used to change any grouping of knob Parameters in one smooth gesture."
    This is a feature the Meris Mercury 7 pedal offers which I was contemplating buying … until I just saw the new Blackhole pedal. 🙂
    Yes, you can use the expression pedals to morph between 2 sets of different parameters, which are like basically 2 presets
