Home › Forums › Products › Stompboxes › pre/post switch via MIDI? › Reply To: pre/post switch via MIDI?
September 20, 2020 at 5:18 am
#155861
JES wrote:
Greetings. Is there a way to assign a MIDI CC or external switch to pre-post on the H9? I know it can be done per preset via the app, but I'm trying to work with a tabletop pedals setup and no touchscreens. The "hold left pedal and click till you get the option" is ok, but a little finicky. Otherwise, really loving the interface implementation on the pedal. Now that I'm not hunched over, I'm able to do a lot more right on it.
What do you mean by "hold left pedal and click till you get the option"
You may use MIDI or aux switch to switch presets. That way you can change presets easily with different Pre/Post settings
