Home Forums Products Stompboxes pre/post switch via MIDI? Reply To: pre/post switch via MIDI?
#155866
JES
    Thanks, but I’m trying to do something different. I’m using the H9 with two loopers.  Sometimes I want it before the first looper and sometimes I want it after the first looper.  The work is improvisation-based and so I’m not working with a set of pre-fab presets.  I’m editing on the pedal.
    If I hold down the left foot switch and click the encoder, I get a number of parameters I can edit per present (inswell, outswell, etc) including pre/post.  This is documented in both the manual and Eventide’s instructional video for pre-post mode.
    Those parameters are in the H9 app, but they are not in the menu for assigning CC messages.
    Are they MIDI-addressable at all, and if so, what MIDI message do I need to send?
