Home › Forums › Products › Rackmount › H9000 as main audio interface over USB QUESTION › Reply To: H9000 as main audio interface over USB QUESTION
September 28, 2020 at 6:17 pm
#155923
I know it’s obvious from the screenshots, but it is worthy of repeating…..Buffer size on its own is not the sole component to characterize low latency performance. If you look at the comparisons above, INPUT latency on the H9000 via USB is considerably higher than the RME via Firewire at the same buffer setting (output latency appears to report pretty close).
