Home Forums Products Rackmount Creating a master output to monitor all FX chains Reply To: Creating a master output to monitor all FX chains
#155953
qepic7
    Kamurah wrote:
    I use Dante instead of USB….but the setup *should* be the same.
    Save the Eventide’s USB 1+2 inputs as the ‘main outputs’ of Ableton.
    The other 14 inputs / outputs will be your sends.  Set up a direct I/O between USB inputs 1+2 and whichever output on the Eventide you want to monitor from.  An example USB 1+2 connected to Analog 1+2
    This way, anything coming from your ‘main mix’ in Ableton will get routed through USB 1+2 to the Analog outputs directly.
    I do it this way only using Dante…where my main outputs of Logic (output 1+2) correspond to Eventide Dante input channels 1 +2.  The Dante input channels 1+2 are then routed directly to the SPDIF outputs.  From the SPDIF outputs I have headphone / monitor controller setup.
    Hope this helps.
    This sounds great, I will try this tonight.  Many thanks!
