Reply To: Volume Boost for Solos
Home Forums Products Stompboxes Volume Boost for Solos Reply To: Volume Boost for Solos
#155969
andrewinthemane
alex jones wrote:
I’m currently building a fly rig with a HX stomp and the H9. Having the output level mapped to a hot switch would go a long way to making this small rig even more powerful. Any update on whether this feature is still coming and when it could be available?
Hey, old thread but I can share a possible solution.
Firstly, on the HX Stomp you could map the master output level (per preset) to one of the two optional footswitches (FS4 or FS5). Set minimum value to 0.0db and maximum to your liking (ex. +5.5db). Saves a block and functions as a clean, end-of-chain volume bump.
Alternatively, you could map the output level of the H9 per preset to an “expression stompbox.” This pedal basically functions like an expression pedal, but instead of a wah-style large footpedal, it’s just a small 1590A size stompbox with an input, output, a single potentiometer to control the maximum value of the expression and a footswitch to bypass/activate. Set the pot to maximum value and viola, you can map it as your own “hot switch” to control anything from output level only, or multiple parameters at once. LED/power not required to function, only if desired for visual confirmation of engagement.
TIP: this kind of “expression stompbox” can also be used with ANY pedal with an expression jack to provide an alternate setting, I once used one to add a second channel to a Bogner La Grange by setting the gain high on the pedal and then engaging the expression stompbox to pull the gain back down. Cheers.
