Home Forums Products Plug-Ins Eventide ‘Magic Air’ Preset Settings Reply To: Eventide ‘Magic Air’ Preset Settings
#155998
So a helpful representative told me some information but not sure how i would do this on the software
 This is the factory settings for Magic Air in Eclipse (Preset #479)
Program:
– Level1: -6 dB
– Level2: -6 dB
– Pitch1: 12 cts
– Pitch2: 6 cts
– Delay1: 84 ms
– Delay2: 144 ms
– Feedback1: 0 %
– Feedback2: 27 %
Parameters for FXA: multishift 2
– Routing: xfade
– Routing Levels (FXA Mix): 100%wet (both)
– Routing Levels (FXA Level): 0.0 dB (both)
Left Channel: -6dB; +12 cents; 84 ms; delay feedback 0%; panned hard left
Right Channel: -6db; +6 cents; 144 ms; delay feedback 27%; panner hard right
Output: 100% Wet; 0.0dB output
Modulation settings (this is where im stuck at)
Settings for Modulation
TTime:
– mode: systemtempo
– ttype: update
– run: 0.000 sec
– delay: 0.600 sec
– bpm: 100.0
LFO#1
– rate: 1.67 Hz
– t_rate: 1/4 note
– shape: sine
– retrig: 1.0 cycles
– angle: 0 deg
– duty: 50%
Retrig
– TAP retrig: off
– audio retrig: off
– thresh: -40 dB
ADSR#1
– adsr: in1
– sens: 32 dB
– retrig: 5 ms
– attack: 200 ms
– decay: 20 ms
– sustain: 100 ms
– release: 100 ms
– dlevel: 60 %
– slevel: 75 %
– trigg att: 0.002 sec
– trigg dcy: 0.100 sec
Follow#1
– env: in 1
– f attack: 0.100 sec
– f decay: 0.100 sec
