Home › Forums › Products › Rackmount › What keeps frying H8000 PHY chips? Firewire fail › Reply To: What keeps frying H8000 PHY chips? Firewire fail
October 17, 2020 at 2:13 pm
#156052
nickrose wrote:
Most likely are differences in the grounding of the two connected systems. Hot-swapping is worth avoiding. The fact that the previous setup did not do this suggests that it is a connection issue.
Grounding may be tricky, Since the experience when I measured 80 V !!!! between two grounds in one room, I always plug all gear to one common plug.
And even smaller voltage difference fries any chip…..
