Home › Forums › Products › Stompboxes › Time Factor – Type B port USB converter to Bluetooth › Reply To: Time Factor – Type B port USB converter to Bluetooth
October 23, 2020 at 8:53 pm
#156128
nickrose wrote:
Actually, if you want to use your TF as a Bluetooth LE peripheral, Yamaha makes/used to make a DIN plugin (MD-BT01) which should do it. Haven't tried it, however.
I look for Yamaha MD-BT01, but I can’t find this available.
I througth that Eventide needs to see the impact of Port Type B to Bluetooth converter.
This will take the Eventide stompboxes to the next level.
