Home › Forums › Products › Stompboxes › H9 no sound › Reply To: H9 no sound
October 29, 2020 at 3:07 pm
#156185
I mean that the effect doesn’t come through. So the sound is like bypass. Other pedals work fine. It is weird, because sometimes the effect and sometimes it doesn’t. Sometimes it helps when I press the expression pedal, sometimes not.
tstern wrote:
It's going to be much easier to diagnose the issue if you remove as much as you can(other than your H9) from your pedalboard chain. That way, you can eliminate possible other causes of issues.
The H9 itself should bypass when it isn't powered, so you will get audio through it.
When you say you get "no sound", do you mean you get no effect, or the dry signal doesn't pass through?
