Home Forums Products Stompboxes H9 no sound Reply To: H9 no sound
#156187
bohan
Mikkotrumpet wrote:
I mean that the effect doesn’t come through. So the sound is like bypass. Other pedals work fine. It is weird, because sometimes the effect and sometimes it doesn’t. Sometimes it helps when I press the expression pedal, sometimes not.
You should connect your H9 to your PC/Mac via USB, reinstall H9's latest software in H9 Control, and then do a factory reset
