Home › Forums › Products › Stompboxes › Write/Erase Loop H9 will not function › Reply To: Write/Erase Loop H9 will not function
#156196
guestantoine
    nickrose wrote:
    guestantoine wrote:
    Same problem here.
    Is there any way to solve that issue?
    Hi – unfortunately, this thread describes two different problems, one with the updater, the other with the looper.
    To which do you refer ?
    I was stuck with the updater problem but problem solved now. I didn’t wait enough time before writing my previous message. I relaunched the H9 and let run the erase and write message for a bit. After 5minutes the update was done. It’s working perfectly now. My bad.
    Thx
