Home Forums Products Stompboxes Help with Stomp box Bypass / Kill dry / effect signal is gone Reply To: Help with Stomp box Bypass / Kill dry / effect signal is gone
#156233
    It might depend on your wiring. But, try setting the last unit to DSP Bypass.
    But, you may have to keep the TF enabled, as it will otherwise shut off any dry signal. Try creating a "do-nothing" very mild preset and use this if you don't want TF.
