Home › Forums › Products › Stompboxes › Help with Stomp box Bypass / Kill dry / effect signal is gone › Reply To: Help with Stomp box Bypass / Kill dry / effect signal is gone
#156243
bohan wrote:
culloa777 wrote:
Sorry, I forgot to mention that I have all rear switches on all boxes set to “in line” since they are going through the effects loop. The Marshall also has a +4db / -10db button on the FX loop, it recommends +4db on rack effects and -10db for stomp boxes…. Could my signal drop be due to this? If I set the rear button of the stomp boxes to “in line” are they now like a rack effect unit?
If you use the parallel loop, it wouldn’t make sense to me if the volume drops.
Yeah you could try that.
So is putting the stomp boxes in “LINE” switch, will that basically make them like a rack effect? To clarify, I have all 3 of my stomp boxes set to In LVL to “LINE” and the Out LVL to “LINE”, and i have the Marshall parallel mix button set to -10db….because if using the stomp boxes in “LINE” mode makes them behave like a rack effect, I’m assuming i would need to set the Marshall parallel mix button to +4db ?
thanks again for all the help.
