Home Forums Products Stompboxes Shimmer, either too subtle pitched signal or too much reverb Reply To: Shimmer, either too subtle pitched signal or too much reverb
#156267
Thanks   for the suggestions,
And about the “info tab”, yes I’ve read it.
Now, looking at this diagram  from an older topic,
https://www.eventideaudio.com/community/forum/stompboxes/h9-shimmer-pitch-decay-etc,
                                             ____________________________<____________________________
                             Inputs –(+) -> Reverb -> Pitchsifters -> EQ Decays and Pitch Decay –>
> Outputs
it seems what I want to achieve is not very likely.
Well, unless Santa brings another mix knob there : )
                                              ___________________________<_______________________________
                             Inputs –(+) -> Reverb -> Pitchsifters -> EQ Decays  -> and Pitch Decay –>
        | —-(additional mix knob) — |
> Outputs
That being said, I’m curious about the next step you’ve mentioned.
