Home Forums Products Stompboxes New Blackhole stompbox Reply To: New Blackhole stompbox
#156307
Hi Joe, thanks for the info. I had already downloaded an update, that now seems to have solved the “bypass” issue and the pedal seems to work normally.
As for the EDM, I managed to see where I was going wrong. What I would like to do is copy a preset into an available slot so I can then edit the original without losing it, if you see what I mean. Can that be done or what is the way I can do that? Cheers Mike
