Home Forums Products Plug-Ins Quadravox Live Mode setting isn’t recalled (Bug) Reply To: Quadravox Live Mode setting isn’t recalled (Bug)
#156325
tlongabaugh
    The fix has now been released.
    Regarding VST3 vs. VST2: the differences you'll notice in terms of performance will be minimal to none. The biggest advantages of VST3 are (IMO):
    • Proper sidechain support (it's kind of a hack in VST2, and doesn't work properly in all hosts)
    • VST3 suspends processing when no audio is passing through it. Many VST2 hosts have this implemented as well, however, so it may not matter depending on your host.
    • VST3s can be categorized by effect type, making searching for them easier (again, depends on how host presents this info)
    • Standardized installation directory on Windows – this makes installation and setup a bit easier
    At the end of the day, you should just use whichever best suits your workflow.
