Reply To: Timefactor – Can’t change parameters
Home Forums Products Stompboxes Timefactor – Can’t change parameters Reply To: Timefactor – Can’t change parameters
#156335
bohan
Are all knobs not working? Does the encoder work? How about the footswitches? It could be a loose ribbon cable in the box.
It's also worth trying to use a USB cable to connect to a PC/Mac and try if parameters change when you change knobs in the H9 Control app
