Home Forums Products Stompboxes TimeFactor & H9 Control won’t Connect Reply To: TimeFactor & H9 Control won’t Connect
#156337
bohan
    Do you use any other MIDI devices? Does TimeFactor connect well if it's the only MIDI device connected?
    Also check your Audio MIDI setup and in the MIDI devices remove/reset all Eventide devices and then try connecting again.
