Home › Forums › Products › Stompboxes › Timefactor- no sound/signal even through bypass › Reply To: Timefactor- no sound/signal even through bypass
November 23, 2020 at 8:52 pm
#156344
I know this post is from a couple years ago, but has anyone found a solution? I am having the exact same problem. Tried different cables, restored factory settings, and still nothing. Is the pedal probably toast or could it be some underlying issue? if theres no sound in bypass I assume theres something wrong with the pedal. Any insight would be greatly appreciated. Thank you
