Home Forums Products Stompboxes Timefactor- no sound/signal even through bypass Reply To: Timefactor- no sound/signal even through bypass
#156360
bohan
    jamesy wrote:
    I know this post is from a couple years ago, but has anyone found a solution? I am having the exact same problem. Tried different cables, restored factory settings, and still nothing. Is the pedal probably toast or could it be some underlying issue? if theres no sound in bypass I assume theres something wrong with the pedal. Any insight would be greatly appreciated. Thank you
    What if you set the Bypass Mode to Relay?
