Home › Forums › Products › Stompboxes › Changing the Learn or Flex Function in to a Repeat or HotSwitch › Reply To: Changing the Learn or Flex Function in to a Repeat or HotSwitch
November 24, 2020 at 3:13 pm
#156371
Hi rik, the plug-ins are designed to follow the functionality of the actual H9 pedal algorithms with minor adjustments in some cases. As such, none of the buttons are configurable in the ways that you mentioned. While there is no way to adjust whether a button latches, it is possible to use some creative MIDI programming to make them behave the same way.
