Changing the Learn or Flex Function in to a Repeat or HotSwitch
Home › Forums › Products › Stompboxes › Changing the Learn or Flex Function in to a Repeat or HotSwitch
    • #116208
      Hi
      In some of the Algorithms there is a Learn, Flex knop (knop in the center of the editor)
      But i do not want a Learn or Flex knop there,
      Can i program that button as a Repeat or a HotSwitch button?
      And can i choose it to react as a latch or unlatch type?
      Thanks
      rik
    • #156371
      joecozzi
        Hi rik, the plug-ins are designed to follow the functionality of the actual H9 pedal algorithms with minor adjustments in some cases. As such, none of the buttons are configurable in the ways that you mentioned. While there is no way to adjust whether a button latches, it is possible to use some creative MIDI programming to make them behave the same way.
      • #156373
        thanks joecozzi
