Home › Forums › Products › Stompboxes › Thanks for the free license for the H9 Series Plug-in Bundle! › Reply To: Thanks for the free license for the H9 Series Plug-in Bundle!
#156440
Bodde
    joecozzi wrote:
    Bodde wrote:
    I run two versions of Cubase on the same computer. On Cubase 7 I can’t see the installed plugins at all. On Cubase 9 they all work. Isn’t the H9 bundle supported by Cubase 7? Is the problem with Cubase or with the plugins?
    Assuming you’re using a Mac, but are you running Cubase 7 in 32-bit mode? That could be the problem, as the H9 Bundle is only compatible with 64-bit systems on Macs.
    Yes I am on Mac. Cubase 7 is 32 bit and Cubase 9 is 64 bit. So the bundle only works on 64 bit?
