Home Forums Products Rackmount H8000FW Unusual crackling noise only on DSP#2 Analog out. Reply To: H8000FW Unusual crackling noise only on DSP#2 Analog out.
#156476
TubeAmpNut
    Thank you for the prompt reply,
    Testing on a few 8 channel presets, as well as the “Thru” preset, the crackles are on all 8 DSP#2 channels and both analog out pairs 1/2 & 3/4
    I should add I also tried all internal clock rates as well as wordclock at 48K.
    Bypassing machine B does not remediate the issue, only using the digital outs does
    Is a routing engine repair a complicated/time consuming one?  Does it require major motherboard fixes?
    thanks,
    BK
    nickrose wrote:
    It sounds as though there is a fault in the routing engine. Probably has to come back.
    Does it vary with different presets ?
    Do you get it on DSP bypass ?
    Does it occur on all analog outputs when driven from DSP 2 ?
