Home › Forums › Products › Stompboxes › Can I run two mics somehow through Eventide Mixing Link for reamping/switching before guitar pedals? › Reply To: Can I run two mics somehow through Eventide Mixing Link for reamping/switching before guitar pedals?
November 29, 2020 at 7:20 pm
#156479
Hi Grace,
I am afraid MixingLink can only support a single Mic while using the FX Loop. The Inst in uses the same gain setting/preamp as the Mic input.
There is a kludge where you could use the ‘From FX’ input (FX Return) as a second mic input, then bring the FX Loop return back in using the Aux In. This may require adding gain on the mic that is used on the ‘From FX’ input.
thanks, JWaltz@eventide.com
