Home Forums Products Stompboxes If the H9 will only be available as Max version… Reply To: If the H9 will only be available as Max version…
#156518
joecozzi
    Technically, if your Max were to malfunction you would not lose all your algorithms on your account. You could find a used Core unit and still take advantage of the fact that you can transfer Max algorithms to up to four H9 Core or Standard units on your account.
    Moreover, because we are continuing to support all H9 models despite the Core and Standard versions being discontinued, in a high percentage of cases, servicing any H9 would cost way less than buying a new H9 anyways.
