Home Forums Products Rackmount Allocation: single_pel_cycles ??? Reply To: Allocation: single_pel_cycles ???
#156526
    This rather unhelpful message is trying to tell you that the patch requires more DSP resources than the Orville can provide. It may be that a parameter in the patch is set too high, or that it has too many modules (if from a sigfile).
    You should reverse your latest changes until the message goes away – there is no easy way to find the exact cause.
