Home Forums Products Stompboxes My ‘increment preset’ switching stopped working, can anyone help? Reply To: My ‘increment preset’ switching stopped working, can anyone help?
#156549
joecozzi
    Check that the switch on the left side of the OX9 is set properly. It should be set to the back position (away from you), if you’re using it in 3-button mode. The forward position (towards you) is best for use with an expression pedal, and this mode causes the right switch of the OX9 to behave like a flex button.
