Home Forums Products Stompboxes Making an octave preset that defaults to expression toe-up? Reply To: Making an octave preset that defaults to expression toe-up?
#156624
terich
    joecozzi wrote:
    Just so I understand correctly, you’re on your PITCHFLEX preset and you move your expression pedal to the Octave up position. Then, you leave that preset for another sound, but then, you go back to PITCHFLEX and want the sound to pick up where it left off, at the octave up position. Is your expression pedal in the toe position as well?
    This would work too, but I was specifically thinking it would also be fine if I could load the preset with high octave by default.
