Home Forums Products Stompboxes Making an octave preset that defaults to expression toe-up? Reply To: Making an octave preset that defaults to expression toe-up?
#156625
joecozzi
    The thing to keep in mind, is that the algorithm doesn't take stock of where the expression pedal is until it is moved. The only way to get PITCHFLEX to give you the same pitch when you come back to it is creating a preset where the HEEL position is set to start at your original preset's TOE pitch. But, as soon as you move the expression pedal, it reverses the direction of the pitch control (because you already started in the higher octave). If all you need is to hear the pitch where you originally left off, this works. But if you need to continue using the pedal after going back to PITCHFLEX this is not going to work, unless you can deal with it functioning in the opposite direction.
