Home Forums Products Stompboxes Expression pedals for H9 Reply To: Expression pedals for H9
#156746
gas hed
    bohan wrote:
    New for H9:
    Mission Engineering has released an expression pedal specifically designed to work with the H9. The SP-H9 has a potentiometer wired as a rheostat and an integrated momentary switch connected to the ring. This allows the customer to connect the expression pedal to the H9 with a single TRS cable and get both expression pedal and switch functionality in the one unit. There is also a parallel switch input so customers can connect an external TS switch just using a regular 1/4” instrument cable. Learn more at: http://missionengineering.com/?product=sp-h9-eventide
    Does this mean I can use the SP-H9 as an expression pedal and also to engage the tuner?
