Home Forums Products Stompboxes Expression pedals for H9 Reply To: Expression pedals for H9
#156747
joecozzi
    gas hed wrote:
    Does this mean I can use the SP-H9 as an expression pedal and also to engage the tuner?
    Yes. If you connect to the H9 using a TRS cable, set the expression input to “Both” mode, and map the “Toggle Tuner” command to Foot Switch 2 (Ring), you will be able to engage the tuner using the built-in footswitch of the Mission SP-H9.
