Home › Forums › Products › Rackmount › H9000/Emote Cubase Integration › Reply To: H9000/Emote Cubase Integration
Thanks for the quick reply. My setup is as follows:
– Windows 10
– Cubase elements 11
– H9k connected via USB, as the only audio interface.
– USB input 1/2 on the H9k are connected to Analog Out 1/2 on the back of the H9K in a through chain (thanks for the pointer to the Direct connection, but I want to change one thing at the time 🙂 )
– Analog Out 1/2 on the Back of the H9K are physically connected to my speaker monitors
With this setup I am able to hear sound coming out of the DAW (or any other Windows application, e.g. spotify, for that matter)
Now I am trying to use the H9K an effects unit on specific tracks and this is where I am having troubles.
What I have managed to do, in order to use the H9k as a send is as follows:
1) Create an output bus in cubase to port 3/4 on the H9K (it says Analogue 3/4 on the cubase interface but actually seems to work as USB in Emote (see below))
2) Send an instrument track in cubase to that output bus
3) In emote connect USB 3/4 as the input of the chain
4) Create an input bus in cubase to port 3/4 on the H9K
5) In emote connect USB 3/4 as the output of the chain
6) Create a new track in Cubase that listens to the input bus created at point 4
7) Now I can either activate monitoring of the track to listen to it, or record to it in Cubase
The above works, even though it feels like i am overcomplicating (?). Anyways the track i create at point 7 is the wet signal from the H9K, and i can hear it through the monitors and record it, so that’s good.
Now i’d like to try and use the H9K as an insert in cubase (like I would use a regular plugin). The problem is when I do that, i have no idea how I am supposed to setup the connections in Emote. If I use USB 1/2 as input, everything gets fed into the chain (as USB 1/2 is the main stereo out in cubase). I tried using all of the other USB inputs in Emote but none of them seem to be receiving sound from Cubase. Similarly, I have no idea how to set up the outputs in Emote. In other words, when using as Insert, i don’t know which USB channels are being fed with audio (and are going to receive audio), so i don’t know how to setup connections in Emote.
I have watched the video you sent, but that seems to be a different case, as it relates to external effects that are physically connected to the interface, not USB connections, and also results in a send-type setup not an insert.
Hope the above explanation makes sense, please let me know if you need more info
Thanks
Federico
