Home › Forums › Products › Stompboxes › Crush Station algorithm very low volume › Reply To: Crush Station algorithm very low volume
        February 2, 2021 at 2:43 pm
        #157020
K-1000 wrote:
>I need to push its output volume to +10dB just to reach unity gain with the H9 bypassed.
That doesn’t seem to be functioning normally. None of my presets or custom settings are set that high, for my rig.
If you want to try an experiment, back up your pedal’s presets to a list on H9 Control. Make a note of any custom system settings you may have. Then, reinstall the pedal’s firmware. Afterwards, conduct a factory reset. Lastly, restore your presets and system settings. See if CrushStation is giving you the same behavior.
