Home › Forums › Products › Rackmount › Tempo via midi in on H9000 › Reply To: Tempo via midi in on H9000
February 5, 2021 at 5:03 pm
#157080
joeydego wrote:
Can I do this USB? I’m not currently connected usb to the computer (was getting an error message and am not using any USB audio).
What is it that you are trying to do?
The USB B connector on the H9000 is just for sending/receiving audio. You can get MIDI clock info from your computer to the H9k via WIFI or ethernet but you'd have to have tempo mode set to DAW and running Emote as a plug-in in your DAW.
You could go MIDI out of your H9k to the axefxiii if you want to have the tempos synced.
