Home › Forums › Products › Rackmount › Dante and/or MADI setup with H9000 › Reply To: Dante and/or MADI setup with H9000
February 7, 2021 at 3:49 am
#157098
zengomi wrote:
First attempts using Dante via Digiface Dante and Logic I/O Utility went swimmingly. Latency as reported in the I/O plugin amounted to 3.5 ms @48kHz and a tad less @96kHz. Sent 2 mono tracks to 2 inputs into a reverb algorithm (mix at 40%) and bounced that down.
Before doing the above, I tried using ADAT. Didn’t sound so nice. Latency was atrocious.
I’ll use headphones to compare the 48 and 96 recordings.
This is odd. My Adat latency in and out of studio one is reported never above 200 samples at 48k (Thats less than 5ms). It’s often only 30 samples on most of the algos I gravitate to.
