Home Forums Products Stompboxes How to select algo preset from pedal? Reply To: How to select algo preset from pedal?
#157244
joecozzi
    These are great suggestions.
    By the way, if you are on a preset and you want to know which algorithm it's using, just press the "Presets" button once. The display will show you the name of the algorithm. Press "Presets" again to return to the preset name.
