Home › Forums › Products › Plug-Ins › macOS 11 Big Sur Support Info › Reply To: macOS 11 Big Sur Support Info
February 24, 2021 at 10:53 pm
#157264
tlongabaugh wrote:
Hey, we’ve been seeing some reports of this problem, following the below steps seem to fix it:
- Close Logic Pro X
- Make sure Finder is the active application
- While holding the Option key, click on the Go menu at the top of your screen and select Library
- Delete the following files from your User Library, if they are present:
- ~/Library/Caches/com.apple.audiounits.cache
- The contents of ~/Library/Caches/AudioUnitCache/
- ~/Library/Preferences/com.apple.audio.InfoHelper.plist
- ~/Library/Preferences/com.apple.audio.SandboxHelper.plist
- Then, open a Terminal window (Applications -> Utilities -> Terminal), and enter the following commands (type each command and press “Enter” afterwards)
- killall -9 cfprefsd
- killall -9 AudioComponentRegistrar
- Restart Logic Pro X
I got my plugins back! ![]()
Thanks it worked like a charm 😀
Best Lucas
