Home › Forums › Products › Stompboxes › TRYING to use Tech 21 Midi Mongoose with the H9 but can’t figure it out. › Reply To: TRYING to use Tech 21 Midi Mongoose with the H9 but can’t figure it out.
#157292
torr71
    Hi and thanks for the reply-
    I have done all of those things, and then some. I have set up the receive channels either to the correct number or just OMNI.
    I tried many cables, some like new ones.
    I’m usually good at this stuff, IDK…
    Me Thinks I may have a bad controller; it does everything that it should be doing to set up the controller. (All controller function are working)
     The next step is try it on something else, not sure what I have that uses MIDI. Any more thoughts on the matter would be appreciated.
    Also waiting on a reply from Tech 21
    Peace
    Mark
