Home Forums Products Stompboxes H9 tuner via G3 atom Reply To: H9 tuner via G3 atom
#157316
joecozzi
    andysalt wrote:
    When I enter the hidden preset (no.9) first time round, the tuner selects on the H9 via a midi PC change.
    Are you sure you don’t mean MIDI CC change? There is no tuner preset on the H9. It has to be engaged sending a MIDI CC# and you can actually customize which CC# to use. Maybe there is a conflicting CC number being used that is causing the problem.
    andysalt wrote:
    If I then press the atom footswitch twice (switch away from the tuner to preset 1…
    What PC # is Preset 1 on the G3 sending?
    andysalt wrote:
    …then back to preset 9, my tuner),
    What commands do you have programmed on the G3’s Preset 9? Again, this should only be sending a CC#. Check if the toggle behavior itself doesn’t have programmable latching behavior, meaning it’s in a different instance with every toggle; some controllers offer this functionality.
    andysalt wrote:
    the h9 then engages in a delay mode (my first saved preset on the h9).
    By this statement, the G3 is sending a PC to the H9. Make sure there is no other command being sent.
    This would be a good time to use the G3 App to make sure your not missing something.
