Home Forums Products Stompboxes ModFactor Startup problem Reply To: ModFactor Startup problem
#157332
bohan wrote:
Does the Eventide Direct Updater recognize your ModFactor when you power it up and connect via USB?
Does it recognize your ModFactor when the pedal is powered into UPDATE mode? To enable the software update, power up while
pressing the Middle Footswitch until [UPDATE] is displayed.
When it’s to put it into update mode, I just get the same dots in column 2 of the display the same way it does when I power the unit up without pressing the middle footswitch.
My computer doesn’t recognize it because I can’t put it into update mode.
