Home › Forums › Products › Stompboxes › One 3-button switch, Two H9s › Reply To: One 3-button switch, Two H9s
Amazing! Thank you! This is such a better solution than a MIDI pedal. Thanks for making something that works so well on its own, as well as through the app.
While I have you, one other question. Is there a way to set the volume for a single preset on the pedal itself? I find sometimes I get to my practice space and I need it to be 1-2db louder or quieter, and it would save me whipping out the phone, connecting, etc if I could just reach down and do it on the pedal.
Yes. It can be done easily in H9 Control. See attached.
On the pedal itself, you can press and hold the Active footswitch, and turn the black encoder to adjust the output level. Remember to save the preset to save your change.
