Home Forums Products Stompboxes H9 Screen Starts to Flicker After a While Reply To: H9 Screen Starts to Flicker After a While
#157450
BassPorn
    bohan wrote:
    OK. You may try
    1. Reinstalling its firmware by using the Direct Updater, which is bundled within H9 Control. It can be found if you click “Window” -> “Open Eventide Direct Updater” in H9 Control’s menu bar on Mac, or by searching “Direct Updater” on Windows’s start menu. You’ll need to boot UPDATE mode by powering up the unit with HOTKNOB button pressed and held to do the update.
    2. After update, try a factory reset by powering up the unit with the right footswitch and the black encoder knob pressed.
    If these don’t fix the issue, you should email support@eventide.com and consider to send it in for repair.
    Hey, Bohan…  Thanks for your precious suggestion…
    Unfortunately, Direct Updater does not appear to be able to communicate with the H9, even over a direct USB cable…
    Guess I should open a ticket?!?  (do consider I live in Italy)…
    Pier
