Home Forums Products Stompboxes Blackhole Pedal Locked(??)/Flashing LEDs….. Reply To: Blackhole Pedal Locked(??)/Flashing LEDs…..
#157488
joecozzi
    Since you have EDM up, let’s try this. Just to make sure you’re not doing anything wrong.
    Disconnect the power for the pedal.
    Simultaneously press the right footswitch and the right LED button above the right footswitch, and while holding them down, connect the power adapter to the pedal.
    You should see two lights blinking on the pedal, preset1 and preset 5. Does that happen?
