Home › Forums › Products › Stompboxes › H9 Hotswitch › Reply To: H9 Hotswitch
March 25, 2021 at 4:43 am
#157523
masterzaffro wrote:
I'd love to see the hotswitch mappable to the tap tempo switch since I'll be using midi clock sync rendering my tap tempo button useless.
When MIDI clock is on, you cannot tap tempo anymore. It's disabled regardless if Tap is mapped to whatever controller. However, if you turn off Tempo mode (that rectangular button in H9 Control, or you can press the right FSW+PRESETS button), you can still use the Tap button on your H9 or in H9 Control, or mapped to whatever MIDI or Aux switch.
