Home Forums Products Stompboxes Space pedal midi input clock enable question Reply To: Space pedal midi input clock enable question
#157532
joecozzi wrote:
All Factor series pedals flash when MIDI CLK is set to ON. The blinking indicates that the ‘Factor pedal isn’t seeing any MIDI clock input. When it recognizes the timing pulse, the blinking stops immediately.
Ah, I see. I will check this out tomorrow; thanks very much for your prompt and helpful reply!
I’m re-sorting a synth midi rig after adding a MidiHub, so some things/midi routings in the rig are a bit different now.
