Home Forums Products Rackmount Configuring H8000FW for dual-stereo using ADAT Reply To: Configuring H8000FW for dual-stereo using ADAT
#157598
dhsimmon
    Sorry to bump an old thread, but I am having the same trouble as a bunch of other folks had earlier.
    I would like to use my H8000FW over ADAT as two parallel effects units, A and B, at 44.1Khz.
    What should settings should I use on the 3 key Setup screens: Inputs, DSP, and Outputs for each of the two processors A and B.
    I don’t use Firewire, so I’d like to be able to simply do this from the H8000FW front panel.
    I cannot understand the relevant sections in the manual, nor can I understand the diagrams that were posted earlier on this thread, so I’d appreciate if someone could just tell me what to do so that I don’t have to learn about the inner workings of this machine.
    Thanks in advance!
