Home › Forums › Products › Stompboxes › H9 preset increment/decrement over 5din MIDI issue › Reply To: H9 preset increment/decrement over 5din MIDI issue
        April 21, 2021 at 12:52 pm
        #157681
Can you take a screenshot of your mappings in H9 Control? Are you certain the CC#s you are using aren’t conflicting with any other mappings already assigned?
Are you certain your controller is sending out correct MIDI data? Have you analyzed it’s output using a MIDI event editor?
