Home › Forums › Products › Stompboxes › H9 preset increment/decrement over 5din MIDI issue › Reply To: H9 preset increment/decrement over 5din MIDI issue
April 22, 2021 at 1:40 pm
#157689
In all my time programming MIDI controllers using Traktor I hadn’t even realised that!!! ![]()
So essentially the bypass/active toggle is the only function working, because I’m telling the pedal to turn OFF the bypass, then turn OFF the active, so it’s cancelling itself. Makes sense!
I’ll get this unit back to have the value changed and hopefully we should be all good!
Thanks again,
Lee ![]()
